Activity Forums Blackmagic Design Rendering issue using the MJPEG preset
  • Rendering issue using the MJPEG preset
    Posted by Jeff Anderson on October 3, 2006 at 3:36 pm
    I updated to the v5.7.1 driver and everything works great except for the MJPEG preset. The captured MJPEG video looks good and playsback good until you need to render. When I add a transition or a title and then render the video will look scrambled and unusable. Has anyone else encountered this problem?
    System Specs . . .
    MB – Supermicro P4SCT+II
    CPU – P4 3.4
    RAM – 2GB
    OS – Win XP SP2
    Video – Matrox Parhelia with dual LCD monitors
    Boot HDD – WD 7200 RPM
    Video array – Stripe set of 4 x 250 GB SATA HDD with Promise FastTrak S150 SX4 RAID controller
    Video Capture – Decklink Extreme v5.7.1
    Video Editor – Adobe Premiere v1.5.1
    Jeff Anderson
    Andrew Mcleod replied 19 years, 11 months ago 2 Members · 1 Reply
  • Andrew Mcleod
    October 4, 2006 at 5:47 am
    Hi
    We are currently looking into this issue with Adobe Premiere 1.5.1.
    In the mean time while we do some testing you can import you clip into a Blackmagic Uncompressed Project 8 or 10bit. Or use Adobe Premiere Pro 2.0 is you have it available.
    email – pcsupport@blackmagic-design.com if myou have anymore questions.
