Activity Forums Apple Final Cut Pro Legacy Rendering issue
  • Rendering issue
    Posted by Leigh Pugin on August 15, 2011 at 11:03 am
    Hi
    I would like to know why I have to render so many times when placing clips on the timeline in my sequence? Is this because I have not converted my footage in the correct format? If so, then what is the best procedure in preventing the render issue?
    Any help appreciated.
    Regards
    Leigh
    Leigh Pugin replied 15 years, 1 month ago 3 Members · 5 Replies
  • Jerry Hofmann
    August 15, 2011 at 11:53 am
    What format did you shoot?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Leigh Pugin
    August 15, 2011 at 1:56 pm
    Hi
    Thanks for the prompt response. The format was 1080/25p for a DV Pal system.
  • Dan Mansfield
    August 15, 2011 at 3:28 pm
    It depends on what format you want to output the project as. If you want to leave the final product as 1080/25p than make sure your sequence settings are 1080/25p. They just need to be the same to avoid excessive renders.
    If you need to have different settings for your sequence, convert your footage to the sequence settings in Compressor. Hope that helps.
    Dan Mansfield
    Point7West
    http://www.point7west.com
  • Jerry Hofmann
    August 15, 2011 at 6:45 pm
    Well, I need more info.. what was the codec used when shot? HDV? HDCAM? avchd? or from a DSLR or?
    Chances are you need to transcode your footage to ProRes using the same frame rate and size you shot. Then put a clip in a sequence. It should ask you to conform, and you should say yes. You shouldn’t have to render anything just by placing it in a sequence after that unless it’s NOT proves… like a graphic or something.
    Jerry
    Current DVD:
  • Leigh Pugin
    August 15, 2011 at 7:50 pm
    Thanks for the response.
    Based on your advice, I will do some testing and see what happens.
    Hopefully The problem is solved.
    Regards
    Leigh
