Rendering is Different From What is in View and Completely Glitchy
Hello, my problem is that when I render out the active view in a project it shows me a COMPLETELY different image from what is shown and completely glitchy.
This is what my renders, no matter what I change, always seem to turn out:
I’ve tried so much to figure out what is causing this weird render.
I’ve disabled everything in my scene and just had a simple cube and light in the view. I’ve disabled all effects. Here are my render settings:
Here’s the active view:
When I render the active view here’s the result:
But when I select to render the image with everything the same it results in this:
And when I enable everything else in the scene it shows the glitchy render again
Even when not using any of the cameras this same exact image renders. Does anyone have any idea why this is happening? I would really really really appreciate any kind of help. Thank you.
