Activity Forums VEGAS Pro Rendering in Vegas 9
  • Rendering in Vegas 9
    Posted by Becky Young on May 18, 2010 at 5:27 pm
    Hello there,
    I just installed Vegas 9.0 pro and am having a rendering issue. The first video i did was fine and rendered perfectly. It was under 5 mintues long. This last one was over 10 minutes and continually told me that there wasn’t enough space even though there was plenty available in the location I was saving the render out to.
    Any help would be much appreciated.
    Becky Young
    Mark Prebonich replied 16 years, 4 months ago 3 Members · 2 Replies
  • Mike Kujbida
    May 18, 2010 at 6:51 pm
    Make sure that your Temporary files folder location in Options – Preferences – General is set to something other than C:\Documents and Settings\USER NAME\Local Settings\Application
    I have a 3-drive system (C is for programs only, D is for captured files and E is for rendered files) and I have a Temp folder on D & E specifically for temp files.
  • Mark Prebonich
    May 23, 2010 at 7:46 pm
    How do you have a TEMP folder on both D and E drives? Isn’t there just one TEMP folder? Also, if one is not getting errors, is it preferable to make this change? I also have multiple drives but have not made this change, however it would be easy to do so. Thanks
    -Mark
