Activity Forums VEGAS Pro Rendering in Vegas 8? No way!
  • Rendering in Vegas 8? No way!
    Posted by Drew Tudose on January 21, 2009 at 3:20 pm
    Hi guys, i’ve been using vegas since 6.0 but i never had so many problems rendering like now.
    I’m having a Q6600 at 2.4 and 2gb of ram, several HDDs all at 7200 rpm (some external USB) and i’m trying to render wmv, avi or any format that would work (HD 1440×1080).
    Most footage was shot with with Sony FX1 and most of it has been previously rendered at the same size. (never without problems!)
    The project is about 3 min long and yes it contains many parts of footage, on different HDDs, many FX, colour correction, resizing, animation and so on but i thought editing software is made to do all these.
    I’m trying to render…not the whole movie, just 10 seconds at the time and maximum 3-5 tracks at a time…no chance!
    I tried moving all the tracks in another project already (and yes i had to re-place all the key frames). I tried nesting. I shut down all other programmes…nothing!
    Everytime i try, vegas gives me an error message or simply shuts down in a very elegant manner: it simply disappears!
    If anyone had similar problems or anyone can give any advice (except “dump Vegas use FC”) i would be forever grateful.
    Thank you
    Drew Tudose replied 17 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    January 21, 2009 at 3:55 pm
    What’s the error message?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Douglas Spotted eagle
    January 21, 2009 at 3:56 pm
    Is your source ONLY HDV footage? Any stills, or other codecs on the timeline?
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Drew Tudose
    January 21, 2009 at 4:14 pm
    No. Some stills mostly PNG, some of the footage is WMV at 720/576 but all footage has been rendered previously in vegas on the same computer.
    I tried to render parts where are only parts of footage from the same original file and is still failing.
    I really don’t know what can be wrong…
  • Drew Tudose
    January 21, 2009 at 4:15 pm
    I’m not next to the computer right now but when i get home i’ll post the error message…is really long!
    Tx for the quick reply.
  • John Rofrano
    January 21, 2009 at 6:36 pm
    How big are the PNG’s? For 720×576 video they don’t need to be any bigger than 720×576 unless you are zooming into them in which you can double that resolution. Extremely large stills will cause problems.
    ~jr
  • Drew Tudose
    January 21, 2009 at 8:05 pm
    “What’s the error message?”
    after few complete crashes i got this message during a render of 10 seconds (9 tracks on solo) with only one jpeg (480×270) and all the FX for those tracks turned off…
    Sony Vegas Pro 8.0
    Version 8.0c (Build 260)
    Exception 0xC0000005 (access violation) WRITE:0xC1C0 IP:0x6CAE12
    In Module ‘vegas80.exe’ at Address 0x400000 + 0x2CAE12
    Thread: ProgMan ID=0xB34 Stack=0x317E000-0x3180000
    Registers:
    EAX=0317f000 CS=001b EIP=006cae12 EFLGS=00210246
    EBX=3ac7651c SS=0023 ESP=0317ef74 EBP=02daa930
    ECX=00000020 DS=0023 ESI=0317ef80 FS=003b
    EDX=0317f0fc ES=0023 EDI=0000c1c0 GS=0000
    Bytes at CS:EIP:
    006CAE12: F3 A5 8B 43 0C A8 05 74 …C…t
    006CAE1A: 0A 8D 54 24 0C 52 E8 D7 ..TR..
    Stack Dump:
    0317EF74: 3AC7651C 3A2C0000 + 9B651C
    0317EF78: 00000000
    0317EF7C: 0317F348 03080000 + FF348
    0317EF80: 00000000
    0317EF84: 3FF00000 3FF00000 + 0
    0317EF88: 00000000
    0317EF8C: 00000000
    0317EF90: 00000000
    0317EF94: 00000000
    0317EF98: 00000000
    0317EF9C: 00000000
    0317EFA0: 00000000
    0317EFA4: 00000000
    0317EFA8: 00000000
    0317EFAC: 3FF00000 3FF00000 + 0
    0317EFB0: 00000000
    > 0317F000: 006CB067 00400000 + 2CB067 (vegas80.exe)
    0317F004: 3AC7651C 3A2C0000 + 9B651C
    0317F008: 0317F06C 03080000 + FF06C
    0317F00C: 3AC764A8 3A2C0000 + 9B64A8
    0317F010: 00000001
    > 0317F028: 006B518C 00400000 + 2B518C (vegas80.exe)
    0317F02C: 02DAA930 02BD0000 + 1DA930
    0317F030: 0317F348 03080000 + FF348
    0317F034: 08225CA3 06530000 + 1CF5CA3
    0317F038: 00000000
    > 0317F0EC: 006C08B4 00400000 + 2C08B4 (vegas80.exe)
    0317F0F0: 3AC764A8 3A2C0000 + 9B64A8
    0317F0F4: 02DAA930 02BD0000 + 1DA930
    0317F0F8: 0317F348 03080000 + FF348
    0317F0FC: 00000199
    > 0317F12C: 006C0EBA 00400000 + 2C0EBA (vegas80.exe)
    0317F130: 090466C0 08EB0000 + 1966C0
    0317F134: 02DAA930 02BD0000 + 1DA930
    0317F138: 0317F348 03080000 + FF348
    0317F13C: 00000199
    > 0317F20C: 006B4CEA 00400000 + 2B4CEA (vegas80.exe)
    > 0317F2D8: 006B4E59 00400000 + 2B4E59 (vegas80.exe)
    0317FFF0: 00000000
    0317FFF4: 00527950 00400000 + 127950 (vegas80.exe)
    0317FFF8: 00AE7AB0 00400000 + 6E7AB0 (vegas80.exe)
    0317FFFC: 00000000
  • John Rofrano
    January 22, 2009 at 12:40 am
    That is a memory access error while trying to write to memory. It could be a faulty RAM chip or just a bug in Vegas. Here is a pretty good article that gives some things that you can try:
    0xC0000005 Access Violation
    The easiest thing to do is check your RAM with a memory test program. If that doesn’t yield anything I would contact Sony tech support first and ship them the project with just that one image and see if they can recreate it.
    ~jr
  • Drew Tudose
    January 22, 2009 at 7:14 am
    Thank you for the reply.
    I tested the memory and no errors were discovered. Just to make sure, i bought another 2Gb and i’ll try rendering again later.
    Sending it to Sony is out of the question since i can’t wait for so long and i live in a country where there is no Sony software rep.
    I’ll use vegas only for simpler stuff, i start to believe is simply incapable of dealing with large amounts of data and FX (not that i know Premiere or FC would deal better with it). I’m sure Windows doesn’t help either.
    Regards
