Activity › Forums › VEGAS Pro › Rendering in Sony Vegas Pro 11
  • Rendering in Sony Vegas Pro 11
    Posted by Charity Meinhart on December 15, 2011 at 8:02 pm
    Hi friends, I made a commercial in Vegas 10 a few months ago, and recently upgraded to 11 and need to update the commercial and re-render the file. Problem is… NONE of the settings I try in 11 work. Some render without audio, some with weird freeze-frames, etc. I’m kinda at my wits end as I really need to get this video off to Comcast. Any of you brilliant videographers care to give me some ideas? 🙂 I’m attaching a screen shot of the settings they prefer to receive… Thanks!!!!
    p.s. I shot with a Canon 7D 1920×1080 24 fps
    Everywhere I go, there I am.
    Toby Gentil replied 14 years, 8 months ago 4 Members · 12 Replies
  • 12 Replies
  • Angelo Mike
    December 15, 2011 at 9:21 pm
    I’ve had Vegas 11 do this a few times. It’s one of the many reasons I haven’t totally switched over to 11. For me, the problem was usually solved by either closing Vegas and opening it again, or restarting my computer.
    What are you trying to render to? If you can reinstall Vegas 10, I recommend just finishing the project in there.
    http://www.scenethroughglass.com
  • John Rofrano
    December 16, 2011 at 1:49 pm
    [Charity Meinhart] “Problem is… NONE of the settings I try in 11 work.”
    It would help if you told us what settings you have tried.
    [Charity Meinhart] “I’m attaching a screen shot of the settings they prefer to receive…”
    I don’t see a screen shot but that would probably help a lot. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Charity Meinhart
    December 16, 2011 at 7:22 pm
    I have tried:
    .avi- file was trying to get to 26 gigs!
    .mpeg- file has no audio
    .mov- file pauses and doesn’t render properly- one render had no audio
  • John Rofrano
    December 17, 2011 at 2:11 pm
    Hi Charity, According to that spec, they prefer an MPEG-2 Transport Stream. What you need to do is use the following:
    1. Select File | Render As…
    2. Select MainConcept MPEG-2 as the Save as type
    3. Select Blu-ray 1920×1080-60i, 25 Mbps video stream as the Template
    4. Press the Custom… button
    5. On the Video tab, set the Video quality to 31 (High)
    6. Select Constant bit rate (bps)
    7. Change the Constant bit rate (bps) to 45,000,000
    8. On the Audio tab Check [x] Include audio stream
    9. On the System tab Uncheck [_] Save as separate elementary streams
    10. Give the template a meaningful name (like HD for Comcast Broadcast) and Save it
    Then use this saved template to render your file and submit it. This should create the MPEG-2 transport stream they are looking for.
    (click the image for a larger view)
    Also they didn’t say anything about audio levels. Usually you need an average loudness of -24dBFS +/- 2dB with peaks not to exceed -10dBFS. Are you sure that your audio is acceptable? (because Vegas doesn’t have a loudness meter to check). I assume you’ve color corrected to ensure all of your colors and luminance are within broadcast safe limits? (just asking to be sure… if you’ve done this before then feel free to ignore) 😉
    ~jr
  • Charity Meinhart
    December 19, 2011 at 8:57 pm
    Whoa! Once again, thank you SO MUCH, John! I’m saving these settings for the future… very helpful! ~Charity
  • John Rofrano
    December 20, 2011 at 4:14 am
    You’re welcome. Let me know if the file gets accepted with this format so that others will know it’s good for use with Comcast submissions.
    ~jr
  • Charity Meinhart
    January 4, 2012 at 10:58 pm
    Sorry it took me so long to reply… your settings worked perfectly, thanks!
  • John Rofrano
    January 5, 2012 at 12:11 am
    [Charity Meinhart] “your settings worked perfectly, thanks!”
    Thank for getting back to us. Now we know what to use for Comcast Broadcast submissions. 😉
    ~jr
  • Toby Gentil
    January 15, 2012 at 7:26 am
    Can someone please help me? I am trying to Render something in Sony Vegas Pro 11. This is the Problem:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 510)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Windowssystem32atioglxx.dll
    Fault Address: 0x0F2A808A
    Fault Offset: 0x00B5808A
    Fault Process Details
    Process Path: C:Program Files (x86)SonyVegas Pro 11.0vegas110.exe
    Process Version: Version 11.0 (Build 510)
    Process Description: Vegas Pro
    If ANYONE could help, it would be amazing! Thank you so much if you can.
    (It Crashes 1/2 way through rendering.)
  • John Rofrano
    January 15, 2012 at 4:02 pm
    [Toby Gentil] “Fault Module: C:Windowssystem32atioglxx.dll”
    It looks like the fault is in a file called “atioglxx.dll”. If you have an ATI graphics card, I’d say it’s perhaps a problem with your graphics card driver. Update your drivers to the latest level to see if this fixes it. If not, you might want to disable GPU acceleration while rendering in Vegas Pro 11.
    ~jr
