Activity › Forums › Adobe After Effects › rendering in sections
Posted by Mathew Lisett on June 5, 2010 at 10:53 pmis there a way to render parts of the footage instead of doign the whole thign in one go?
Steve Roberts replied 16 years, 3 months ago 2 Members · 10 Replies -
Steve Roberts
June 6, 2010 at 12:00 amYou change the start and end of the work area, then render.
Your Render Settings should be set to “render work area” to make this possible. -
Mathew Lisett
June 6, 2010 at 5:10 pmthanks steve.
now since we have foudn that my system doesnt have enough memory to do the whole footage and the footage needed to be quicktime format.
ive just tried to do from the previous sony area and export it into sections.
so I have a first clip of 30 minutes from sony from the start.
my question is how do i take this section and replace the same selected time period of the footage into adobe without again causing my filters ive set to go away, or indeed the other footage that i need to stay there untill later when i do the exact same thing .
Mathew Lisett
June 6, 2010 at 8:02 pm[IMG]https://i48.tinypic.com/2h3zh4w.png%5B/IMG%5D
now this is what i see either in sony or AE, is this normal as it seems to happen 3/4 or near the very end of the encoding.
and this was just with a 10 min section
it was with animation with quicktime, so im now doign it with png
Steve Roberts
June 6, 2010 at 10:37 pmYour link doesn’t work for me, sorry. Could you place a space on each side of the URL?
As for your problem, I’m not sure I understand, but here goes: Do not change any layers in your composition. Lock them all. The only thing you should change is the start and end of the work area (check the help).
Yes, if you render to a numbered PNG sequence, you can render in sections. Once you’re done, import the rendered sequence into AE, and drag it onto the new comp button at the bottom of the project window to make a comp. For audio, I’ll leave it up to you as to how to get the desired audio into this comp. Render this comp to a Quicktime movie — it shouldn’t take as much RAM given that you’re just rendering frames with no effects, no multiple layers.
Steve Roberts
June 7, 2010 at 1:42 amYou mean you get a Vegas error? If that’s so, you should check the Vegas COW forum.
Mathew Lisett
June 7, 2010 at 2:16 amok sorry, just thought since its roughly the same error with sony aswell as AE cs5, thought there may be some knowledge of the error
Steve Roberts
June 7, 2010 at 12:00 pmHave you checked your hard drive properties to see if you’re running out of disk space?
When rendering, what does AE say is the expected final file size?
Are you using the FAT file system on your hard drive, which doesn’t allow files bigger than 2 GB?
Can you get an external hard drive and format it to NTFS so you can make a file bigger than 2 GB? -
Mathew Lisett
June 7, 2010 at 12:24 pmHave you checked your hard drive properties to see if you’re running out of disk space?
OVER 400gb space free
it doesnt becuase i see the file size grow rom scratch theres no temp file size set.
whole system is ntfs
dont have an external and cant get hold of one
Steve Roberts
June 7, 2010 at 1:01 pmHm. Usually AE indicates an estimated file size when rendering. Oh, well.
I recommend you hit the Vegas forum. I’m out of ideas, sorry.
