Activity › Forums › Apple Final Cut Pro Legacy › rendering in low rez
  • rendering in low rez
    Posted by Paul Nevison on March 22, 2007 at 3:27 pm
    Now many moons ago you used to be able to render in lower than full rez for quick estimations….this was replaced pretty much by RT extreme. Is it still possible somewhere in the menus to render at low rez for quick preview render passes? (other than quickview) I’m looking for full frame rate renders so I can check motion etc and dont mind if it’s wildly pixelated.
    thanks
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 6.0
    PAL Land
    Rafael Amador replied 19 years, 6 months ago 3 Members · 3 Replies
  • Rafael Amador
    March 22, 2007 at 4:07 pm
    Long ago Appel promoted the use of RT OFFLINE easy set-ups for that purpose. The truth is that I’ve never used it and I don’t know if renders fast enough to be worth but is supposed to work well for RT preview.
    Cheers,
    rafael.
  • Randy Johnson
    March 22, 2007 at 4:16 pm
    I believe there is a render resolution option in your user prefrences under the render Tab.
    There is a % based option there…never used it but I remember seeing there.
  • Rafael Amador
    March 22, 2007 at 4:49 pm
    Good Idea. That may work.
    rafael
