Activity Forums DaVinci Resolve Rendering in FX 4800 and GTX 285
  • Rendering in FX 4800 and GTX 285
    Posted by Hisayuki Yamamoto on October 25, 2010 at 12:40 pm
    I tried compare between FX 4800 and GTX 285 with Mac Pro 2009.
    Mac Pro 2009(4,1)
    RAM 12GB
    Internal RAID-0 with x3 1TB HDDs
    FX 4800 or GTX 285 / Slot-1
    GeForce GT 120 / Slot-2
    RedRocket / Slot-3
    DeckLink 3D / Slot-4
    FX 4800 + REDRocket
    R3D, 4kHD, 30fps –> HD1920x1080/DPX10bit・・・1min15sec
    R3D, 4kHD, 30fps –> HD1920x1080/ProRes422HQ・・・1min9sec
    HD1920x1080/DPX10bit –> HD1920x1080/DPX10bit・・・2min36sec
    HD1920x1080/DPX10bit –> HD1920x1080/ProRes422HQ・・・1min53sec
    GXT 285 + REDRocket
    R3D, 4kHD, 30fps –> HD1920x1080/DPX10bit・・・1min7sec
    R3D, 4kHD, 30fps –> HD1920x1080/ProRes422HQ・・・1min19sec
    HD1920x1080/DPX10bit –> HD1920x1080/DPX10bit・・・2min35sec
    Does this helpful to you?
    Hisayuki Yamamoto / Technical Director
    https://mount-q.com
    Tokyo JAPAN
    Hisayuki Yamamoto replied 15 years, 11 months ago 6 Members · 9 Replies
  • 9 Replies
  • Gary Taylor
    October 25, 2010 at 2:24 pm
    Thanks Hisayuki!
    That was very helpful. What was the length of your footage?
    Gary
  • Uli Plank
    October 25, 2010 at 2:51 pm
    Thank you, that’s great!
    Did you try Color with the same hardware? I’m just curious how much faster Resolve is.
    Regards,
    Uli
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Bastiaan Houtkooper nsc
    October 25, 2010 at 3:33 pm
    Not sure about the 2009 version but shouldn’t your REDrocket be in Slot 4 to get at least 4 lanes?
    Resolve system:
    MacPro 8 core 2010 – 16B memory
    9TB harddisk (1 system disk, 8TB in software raid 0 for data)
    Nvidea GTX285
    Nvidea GT120
    Blackmagic SDI Decklink
    RedRocketcard.
    Also running it on a MacBook Pro 17″ (5.2)
  • Danny Scotting
    October 26, 2010 at 12:08 am
    Great info and just goes to show if you have the right system it is worth waiting only 10-15% longer for 10bit DPX instead of ProRes422 to keep the online and effects work high quality!
  • Hisayuki Yamamoto
    October 26, 2010 at 8:47 am
    Though it has been forgotten to write, this footage have 1800 frames.
    I have not done this comparison with Color yet.
    When I did R3D in rendering by using Color, it very took time.
    I think it is unquestionable because it is a specification as which both Slot-3 and 4 are the same.
    https://mount-q.com
    Tokyo JAPAN
  • Sean Kapleton
    October 26, 2010 at 9:17 pm
    hello Hisayuki,
    great post – just curious how exactly and what type of monitoring are you using going out of your macpro?
    cheers
    sean
  • Hisayuki Yamamoto
    October 26, 2010 at 11:38 pm
    It is possible to measure at this time and it calculates from the time stamp of the file that goes up. The QuickTime file was calculated at the date and time of creation and the last update time.
    The display that I often use is CG series made of NANAO. CG232 and CG243 are used this time.
    https://mount-q.com
    Tokyo JAPAN
  • Sean Kapleton
    October 27, 2010 at 9:23 pm
    CG243 is what you use ok great i will compair on b&h.com to the Dreamcolor (they seem to be in the same price point). Might I ask exactly how do you connect from your macpro to keep 10 bit rec. 709 accuracy?
  • Hisayuki Yamamoto
    October 27, 2010 at 11:21 pm
    Sean-san
    CG243 is used in 8 bit mode. (NOT 10bit) It connects it with Mac by DVI. REC709 is not used at this time because the color space is a native of Mac. If REC709 is necessary, the video monitor is connected and handled from the DeckLink card.
    https://mount-q.com
    Tokyo JAPAN
