Rendering in aspect ratio 1.85 has weird results
John Rofrano replied 13 years, 3 months ago 2 Members · 14 Replies
Riccardo Leone
May 8, 2013 at 11:05 amIt is already checked. Tried to uncheck it and check it again, with no result.
John Rofrano
May 8, 2013 at 11:54 am[Riccardo Leone] “It is already checked. Tried to uncheck it and check it again, with no result.”
Something is not right. When I uncheck it I see black bars. When I check it the black bars go away. If I uncheck it and open Pan/Crop and select Match Output Aspect the aspect ratio changes and the black bars disappear. I’m not sure why you are not seeing the same behavior.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Riccardo Leone
May 12, 2013 at 10:06 pmOh, don’t worry about it. I can always letterbox and then use something like mpeg streamclip to crop the whole thing.
Thanks for the help – I gave up! -
John Rofrano
May 13, 2013 at 12:07 pmWell… in the future, start you project with the correct aspect and you won’t have these problems. Take care,
~jr
