Activity Forums Adobe After Effects Rendering in After Effects for Final Cut Pro
  • Rendering in After Effects for Final Cut Pro
    Posted by Gaura Gopala on May 2, 2005 at 6:49 am
    I’m having trouble using rendered quicktime movies from After Effects with Final Cut Pro.
    I have made a short title screen that zooms in on a high res picture (as the backround) with AE’s text effect. When I view the final product in quicktime it looks great but as soon as I put it in FCP and render it, it starts oscillating and jittering. It looks like I’ve got the field render wrong or something.
    I have tried many different render settings in After Effects but none seem to make much of a difference.
    Generally I use:
    Full quality (of course)
    lower field first
    29.9 fps
    either ANIMATION or NTSC DVPRO
    Premultiplied matted
    Exporting to quicktime
    In this case I didn’t used any footage, I only used PSD files and some effects
    Any suggestions would be much appreciated…
    Orcist
    Tim Vaughan replied 21 years, 4 months ago 2 Members · 1 Reply
  • Tim Vaughan
    May 2, 2005 at 11:20 am
    Are you previewing the output on an NTSC monitor? As my own rule, I use the animation settings for output in AE. When brought in to FCP, the movie looks very grainy. (same goes for all text in FCP–it looks like garbage unless viewed on an external monitor) If you are monitoring the output on an NTSC monitor, you should find completely different results. If you do not have an monitor, export the timeline to a movie and burn it to a DVD and check yourself.
    Hope this helps
    Tim
