Activity Forums VEGAS Pro Rendering in 8 bit, but not 32 bit?
  • Rendering in 8 bit, but not 32 bit?
    Posted by Jack Monkiewicz on May 14, 2011 at 3:41 am
    I have encountered an issue with rendering yet again.
    The project im working on wont render out in 32 bit floating, or full range, but will in 8 bit.
    my project settings are:
    HDV 1080 50i – 1440 1080, 25fps
    full resolution rendering quality set to ‘good’
    file type – MXF, with a few avi’s
    My PC specs are
    i7 930@2.80GHz
    12GB Ram
    64 bit system
    is there any benefit for 32 floating/full range? is there a noticeable drop in quality?
    Thank-you in advance for anyone’s help.
    Jack Monkiewicz replied 15 years, 4 months ago 2 Members · 2 Replies
  • John Rofrano
    May 14, 2011 at 5:09 pm
    [Jack Monkiewicz] “is there any benefit for 32 floating/full range? is there a noticeable drop in quality?”
    32-bit has to do with the arithmetic that is used to process colors internally by Vegas. Normally it is not need and 8-bit is more than adequate which is why it’s the default. I wouldn’t worry about it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jack Monkiewicz
    May 14, 2011 at 11:59 pm
    Thanks John, If the quality isn’t impeded noticeably i’ll stick with 8 bit. Thank you again.
