Activity Forums Apple Final Cut Pro Legacy Rendering Help
  • Posted by Jason Smith on May 13, 2009 at 11:57 pm
    Can anyone suggest a better or faster way for me to complete this project?
    100 videos, 30 minutes and 45 minutes each.
    1 graphic overlay with the same logo that goes on each video for the length of the video…(like a cbs or abc icon when watching tv)
    Render takes 1 to 1.5 hours for each video and I’ve been doing them one at a time unlike compressor where you can create a batch. Once red
    I’m using
    8 core
    6gb Ram
    FW800 drives
    FCP 6.0.5
    Any suggestions would be great, thanks!
    Richard Sanchez replied 17 years, 3 months ago 2 Members · 5 Replies
  • Richard Sanchez
    May 14, 2009 at 12:36 am
    There is a batch export function in Final Cut. Select all sequences, go to File > Batch Export and set the destination and you’re going. Likewise, you probably could do it in compressor with the watermark filter to get your overlay on. If you have a Kona 3 card, you can use their downstream keyer to get your graphic on in real time as you lay to tape.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Jason Smith
    May 14, 2009 at 4:29 pm
    Tried to use Export Batch but it is greyed out when the sequence has a red bar on top. It would have been awesome to render 5 open sequences and export them all at once. Even if it still took 5 hours, I would not have to go back to the computer each hour. Alas, this didn not happen.
    Note: in compressor I load up 10 files and compress in my sleep. Videos that took 10 hours on my macbook pro take 1 hour on the octo-core as I’ve set up all 8 cores to work…using 90% of the system. Compressor setup is Great!
    Just need help with Rendering and speeding that up.
  • Richard Sanchez
    May 14, 2009 at 5:30 pm
    That’s weird about the batch render being greyed out. Usually if you have unrendered stuff in the timeline, it will still export, it just takes a little longer since it has to render on the fly, but if compressor is doing for you, that works too! I’ve always had issues setting up compressor for multiple cores, though maybe it’s different as I’m on a Quad.
    Richard Sanchez
    North Hollywood, CA
  • Richard Sanchez
    May 14, 2009 at 5:48 pm
    Oh, you were trying to select them in the timeline? I’m sorry, I should have been more specific. Select the sequences in the Browser Window.
    Richard Sanchez
    North Hollywood, CA
  • Jason Smith
    I tried a test last night on your suggestion for a 15sec. clip..add v2 track with graphic, select drop shadow, bar goes red on top in timeline. From there I could not click on the next tab, the next open sequence? And batch export is greyed out?
    For your Quad core you can get 4 cores all working in compressor. Here is how:
    System Preferences – QMaster – Select Compressor under the Service tab and then click the Options for selected service tab. Number of Instances should show 1. Change this number to 4 Click the bottom right ‘start sharing’ tab.
    NOTE: To use this setting you must select the new cluster when you hit submit in Compressor.
    Example: Hit submit…setting importance is high as normal…where it says “use this computer”…click the drop down and pick the ‘cluster’
    You are all set! Watch your compression work with ALL 4 Cores! And at Blazing Speeds. Hope this helps and if you know anyone on the render issue please pass my question on. Thanks.
