Activity › Forums › Adobe After Effects › rendering help
  • rendering help
    Posted by Marley Bishop on September 13, 2008 at 6:16 pm
    ok.. When I export a file in after effects through file>export it exports it in somewhat bad quality.. but it’s 355 mb
    when I do it through the render queue it looks great, but it’s 15.5 gb
    I need something in between, so that the file size is low enough to be put onto youtube, and the quality is good enough to be tolerable.
    also, if it helps, I have after effects 7, and the video is 9:35 minutes
    Roland R. kahlenberg replied 18 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 15, 2008 at 1:52 am
    Youtube has an upper limit on filesizes (1GB) and duration (10 minutes) for video. Unless of course if you have a Guru Account with them.
    Try rendering out as an MPEG4 or H.264 format with 2500kbps setting. Audio set at 128kbps should be sufficient. Allow for automatic keyframes setting or the default of 50 also works well for most footage. If you have a lot of fast-moving imagery, then lower the keyframe setting to 5 or 10. Alseo, setting the framerate to 18 helps in reducing filesize.
    And, in future Qs, please provide more information instead of just spelling out the problem. You would have done better if you had stated the actual export and render/output settings that you used.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
