Activity Forums Apple Final Cut Pro Legacy Rendering hell! Need advice
  • Rendering hell! Need advice
    Posted by Abcd Zz on September 4, 2012 at 9:02 pm
    I need help!
    Everytime I render a clip on my sequence, every other clips in the sequence needs to be rendered again (yellow bar). The strange thing is sometimes it is alright. I have been editing for the last 2 years and never had such a problem. This is a new project and I recently acquire a new hard drive for it. Sequence setting matches with clip codec- Prores 422 so I doubt it is an issue. I am using lots of effects on each of the clip, particular Twistor.
    Arrrgghh this is so frustrating. Am I misssing something?
    Abcd Zz replied 14 years ago 2 Members · 2 Replies
  • Sam Lesante jr.
    September 4, 2012 at 9:25 pm
    Off the top of my head, It could be the fact that u r using alot of effects and/or maybe there’s an issue with the hard drive. I also find that if i have alot of other programs open it slows down too.
    My two cents 🙂
  • Abcd Zz
    September 4, 2012 at 9:55 pm
    Actually I just realized this is how it goes:
    I open the final cut file. (all looking fine), but when I render a clip, the whole sequence needs to be rendered (yellow bar). After rendering the whole thing, (like some 3 hrs). I can continue to edit without rendering. No problem.
    But whenever I quit program, and open again. The process above starts again. Sighhhhh
