Activity › Forums › VEGAS Pro › rendering hd to burn a dvd
  • rendering hd to burn a dvd
    Posted by Jacqui Brookes on February 6, 2010 at 3:51 am
    hello, can some please help me, I need to render off a 30 min piece of footage from an hd1080i project, to burn to dvd, without losing too much quality. What render setting should I use, and is dvd architect the best program to use to burn it? thankyou for any help. Jacqui
    Jacqui Brookes replied 16 years, 7 months ago 2 Members · 2 Replies
  • John Rofrano
    February 6, 2010 at 6:32 pm
    You should render using one of the MPEG2 DVD Architect templates in Vegas (depending on if you are NTSC or PAL, you didn’t say) and then render your audio separately as AC3. Drop both the MPG and AC3 file into DVD Architect and author your DVD. This will maintain the highest quality but SD DVD’s have 4x less information than HD so don’t expect it to look the same.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jacqui Brookes
    February 7, 2010 at 9:39 am
    Thankyou John!
