Activity Forums Maxon Cinema 4D Rendering hair
  • Rendering hair
    Posted by Jack Cook on June 17, 2013 at 7:28 pm
    I’m using hair to make some grass on the sea floor, and having a problem. First of all, I’m using Cinema ver. 14 on the Mac. Here’s the problem: The main issue is with the length not rendering. I’ve made the hair, tweaked it for variation, color, etc., and it looks great in the editor. When I render in the editor it looks the way I want it, the length is right. But when I render to the Picture Viewer the hair renders as tiny little nubs, instead of long grass. I went into the render settings and in the Object tab of the Hair Render section the length was set to 0.2. So I set it to 40 (using meters as the unit) and rendered again, and no difference at all. In the hair material the length is set to 100%, and the amount to 100%. How can I get the hair to render the way it looks in the editor when it renders there?
    thanks,
    Jack
    Adam Trachtenberg replied 13 years, 2 months ago 3 Members · 5 Replies
  • Dan Conrad
    June 18, 2013 at 12:52 am
    What’s the Root Guide Length? Try playing with that in the Hair Object.
    http://www.mographcandy.com
    Twitter: @mographcandy
  • Jack Cook
    June 18, 2013 at 11:20 am
    Thanks, Dan. The root guide length is 21m. I’ll mess with it and see what comes up.
    Jack
  • Dan Conrad
    June 18, 2013 at 12:03 pm
    post your scene file if you continue to have problems.
  • Jack Cook
    June 18, 2013 at 1:32 pm
    Hi Dan,
    Unfortunately the file is 91MB. It’s filled with thousands of objects and stuff. I found that if I copy the hair object and put it into a new blank file it seems to render properly, so I don’t know that a stripped down file would show the problem.
    Jack
  • Adam Trachtenberg
    June 18, 2013 at 4:16 pm
    Try selecting everything and pasting into a new file.
