Rendering H.264
Posted by Scott Sullivan on June 17, 2013 at 2:45 pmOk I want to host videos that will stream from Amazon S3 server and play them on a blog with JWplayer. I’m told I need to render in H.264.
Up to now I have been using the Video4YouTube plugin (which I love), but I cannot find out how to make that render in H.264.
Also, I don’t even know how to tell if a rendered video is in H.264 format or not.
Can someone help me with this?
Norman Black replied 13 years, 3 months ago 3 Members · 8 Replies -
Norman Black
June 17, 2013 at 9:48 pmAVC = H.264
therefore, Sony AVC and MainConcept AVC are the encoders for your needs.
MainConcept AVC supports the streaming feature for MP4 files. This allows a video to start playing before fully downloaded. You can do this to any MP4, but you use another utility program to modify the file.
Aleksey Tarasov
June 18, 2013 at 9:33 amVideo4YouTube renders your video with Sony AVC. It produces H.264 video in MP4 wrapper.
And, since you want to host video on S3, make sure you select “FastStart” option (and uncheck “Upload to YouTube”).Light Leaks Effects | 35mm Film Grain | Stabilize GoPro footage
Scott Sullivan
June 18, 2013 at 8:54 pmIF I use the “Fast Start” option for Video4YouTube, do I still need something like MP4 fast start?
The reason I ask is because my video plays in slow player but is EXTREMELY SLOW.
https://www.muaythaiu.com/?p=58
Why is this video playing so slowly? I rendered it in Video4YouTube and checked the Fast start option there.
What is the problem?
Norman Black
June 19, 2013 at 1:49 amWhat is the bitrate of the MP4 file?
I only seem to be getting 70,000 bytes per second from the server. That is certainly a problem for video streaming.
Aleksey Tarasov
June 19, 2013 at 4:24 am> “IF I use the “Fast Start” option for Video4YouTube, do I still need something like MP4 fast start?”
No
> “The reason I ask is because my video plays in slow player but is EXTREMELY SLOW”
It depends on the bitrate.
Do you use plain Amazon S3 server for hosting or Amazon S3 + Cloudfront (CDN)?
S3 is fast but it’s not as fast for hosting high bitrate videos. Try to render with lower quality (e.g Good).Probably, Video4YouTube is not the best option for low-bitrate videos. You can try Handbrake.
Why Amazon S3? You can host your video on YouTube/Vimeo and don’t worry about bitrates, network speed etc.
Organic Light Leaks | Film Grain | Fix Barrel Distortion
Scott Sullivan
June 19, 2013 at 2:31 pmHi Norman – I’m not sure. I just rendered it through the Video4YouTube plugin. By “server” do you mean my hostgator server or the Amazon s3 account? The video is on Amazon S3.
Scott Sullivan
June 19, 2013 at 2:34 pmAleksey – thanks for the bit rate advice.I will try that. I am using S3 because the videos will be going into a membership site.
I’ll look into handbrake too.
Norman Black
June 19, 2013 at 2:51 pm“server” I mean whatever is sending me the video file. It may or may not be different than the server sending me the video file. I am using the Chrome browser and I was watching the amount of data received per second by Chrome in the Windows 7 resource monitor.
Peoples internet connections are typically not very fast so you better know what bitrates you are encoding your video to. I am assuming the Amazon S3 will let you serve whatever bitrate you want from a video file. I say this since services like Youtube, Vimeo, Smugmug all re-encode videos to their own standard bitrates.
