Activity Forums Apple Final Cut Pro Legacy Rendering green line at bottom of frame
  • Rendering green line at bottom of frame
    Posted by Jimmy Spangler on May 26, 2008 at 7:02 am
    Hello,
    I am Onlining a spot that is 4×3 Anamorphic 10 Bit Uncompressed and when I render there is a green bar being put at the bottom of the frame. It seems to happen on some of the transitions and only lasts a frame.
    I have messed with some render control settings but those have not had any effect. Also one of my white color solids was rendering as bright blue for no apparent reason. I was able to fix it by making a new color solid.
    Anyone else had problem with render artifacts/glitches such as these?
    I am on a Quadcore 3.0 Intel, 4 gigs RAM, Kona 3.
    Jimmy Spangler replied 18 years, 3 months ago 3 Members · 3 Replies
  • Sean Oneil
    May 26, 2008 at 8:54 am
    I’ve had problems with mysterious green lines, as well as problems with a full green screen. There’s a lot of scattered topics on this. I think the first thing to do is trash your FCP preferences. As well as your QT preferences and AJA preferences. And reinstall all the AJA software.
    Sean
  • Rafael Amador
    May 26, 2008 at 9:01 am
    Hi Jimmy,
    The transitions are you using, are the FC standard transitions?
    I had this green line when using a Freeware filter some time ago.
    I think that that filter couldn’t support 10b.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Jimmy Spangler
    May 30, 2008 at 7:28 am
    Yes, all of the effects were standard FCP dissolves and transitions. It seems to be just this particular project that is causing it. As an FCP user I have become used to strange things happening for no apparent reason.
