Activity › Forums › Adobe After Effects › Rendering graphics to suit 1080i 50hz
Posted by John Mark on July 20, 2013 at 11:51 amHello,
I’m trying to output graphics to a tv display, with the output settings are set to 1080i 50 (via a UltraStudio min monitor from Black Magic). I know 50hertz is PAL 25fps, which I’ve tried rendering( HDTV 1080 25). I just can’t seem to get a smooth playback. Any way I can fix this?
Thank you in advanced.
A News Graphic Lover
Chris Brett replied 13 years, 1 month ago 2 Members · 5 Replies -
Chris Brett
July 20, 2013 at 6:12 pm… and if so and its not right make sure the imported footage and comp settings are correct — if any of these are wrong you get a dicky result —
— also some formats are lower field first so if you are using one of these dont forget to import it correctly …
………………. all the best —-chris —
John Mark
July 20, 2013 at 11:18 pm[chris brett] “– did you set it to upper field first ? —–chris—
“No, where can I do this?
John Mark
July 20, 2013 at 11:19 pm[chris brett] “… and if so and its not right make sure the imported footage and comp settings are correct — if any of these are wrong you get a dicky result —
“All the graphics are made within After Effects, what would be the ideal comp settings? (fram-rate etc)
Thank you.
Chris Brett
July 21, 2013 at 6:40 pmHi John – apologies for delay – been busy ….
RE checking field order – its in 2 area….
1 ) WHEN YOU RENDER
Under render settings / best settings / field render / upper field first
2 ) WHEN IMPORTING FOOTAGE INTO AE
Make sure the import settings match the footage ie if the source material is ‘UPPER’ make sure the import setting is on ‘UPPER’ —– ( same with other import settings )— best watch this one as some HD Cams ( I think ) have lower field first…. if not sure suggest you talk to cameraman…..
IMPORT SETTINGS — these can be accessed by ‘right clicking’ footage ( as listed in panel at top left of AE layout ) and selecting correct option boxes.
If the source material is smooth in the first place and no effect ( or whatever ) is applied that might cause the jittering then this will probably sort it for you…..
All the best
Chris
