Activity Forums Adobe After Effects Rendering gradients for final output
  • Rendering gradients for final output
    Posted by Michael Niemcewicz on May 31, 2007 at 1:09 pm
    I’m about to finish and output to DVD a 2 minute promo that has a few gradients in it. Done in AE and FCP (NTSC DV). Should I take the sequence from FCP to After Effects and redo these sections at 16 (or even 32 bits)? Lossless render? Will I see a difference? It’s getting compressed to MPEG2 anyway.
    What if I just rendered gradients as elements and bring them to FCP?
    Steve Roberts replied 19 years, 3 months ago 2 Members · 3 Replies
  • Steve Roberts
    May 31, 2007 at 1:39 pm
    Sometimes rendering to a 10-bit-per-channel codec (e.g. Blackmagic 10-bpc) lessens the banding when going to MPEG-2. You’d have to render the gradients first (before any other compression) to the 10-bpc codec. Then you might want to bring them into FCP in a 10-bpc timeline, then render that to 10-bpc before compressing to MPEG-2.
    You might need to add a bit of noise to the gradient anyway, though. Hope that helps.
  • Michael Niemcewicz
    May 31, 2007 at 1:51 pm
    Will Apple’s Uncompressed 10-bit codec do? I’m on a laptop.
  • Steve Roberts
    May 31, 2007 at 1:53 pm
    Sure, give it a go.
