Activity › Forums › Adobe After Effects › RENDERING- Good Quality Small File Size
  • Steve Roberts
    March 22, 2007 at 11:55 pm
    Check out the Compression Techniques COW, as this is a codec question, not an AE question.
    Once they advise you on a codec, you go back to AE, choose “make movie” for your comp, then choose the recommended codec in the Output Module.
  • Darby Edelen
    March 23, 2007 at 12:09 am
    Whenever you compress something you’re going to lose quality (unless it’s lossless compression, which doesn’t compress your file very much). H.264/AVC is a good codec (it’s what is being used for most HD/Blu-ray DVDs) for quality:file size ratio but you’ll still lose quality.
    Depending on where your video is headed I’d recommend H.264 (Web, HD-DVD), MPEG-2 (DVD) or Uncompressed (Anything Else).
    Note that you can change the data rate of most compression codecs. Higher data rate = bigger file but generally better quality.
  • Ronaldo Montalvo
    March 23, 2007 at 7:02 pm
    for the mac and quicktime i’m a big fan of the h264 codec, at high to best quality i can’t really see a difference from the animation source movie even with motion graphics, and the file sizes are amazing for the quality. it’s especially handy when i need a source clip from someone to be posted on ftp or idisk. once you get it downloaded export it out of qtime pro to a lossless codec and continue working with it in afx as needed.
