Activity › Forums › VEGAS Pro › rendering gives poor quality and sound track with no sync
  • rendering gives poor quality and sound track with no sync
    Posted by Andrew Taylor on September 25, 2019 at 2:45 pm
    Hi ]
    I am rendering a sony 16 project consisting of a video and audio track
    I am using magic avc/aac and internet 4k 2160 at 25 fps
    Result is poor or no audio PLUS audio out of sync
    settings:
    https://www.screencast.com/t/mlirvvdo
    here is the media info
    Any help appreciated. I have never managed a correct production yet using vegas
    thanks
    Art
    General
    Complete name : C:\Users\Andrew\Documents\Movie Studio 16.0 Platinum Projects\vs1-66-slides-short-render.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (isom/mp42)
    File size : 63.5 MiB
    Duration : 27 s 160 ms
    Overall bit rate mode : Variable
    Overall bit rate : 19.6 Mb/s
    Encoded date : UTC 2019-09-25 14:26:51
    Tagged date : UTC 2019-09-25 14:26:51
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L5.1
    Format settings : CABAC / 3 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 3 frames
    Format settings, GOP : M=4, N=15
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Variable
    Bit rate : 19.4 Mb/s
    Maximum bit rate : 48.0 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.094
    Stream size : 62.9 MiB (99%)
    Language : English
    Encoded date : UTC 2019-09-25 14:26:53
    Tagged date : UTC 2019-09-25 14:26:53
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Duration : 27 s 157 ms
    Bit rate : 192 kb/s
    Maximum bit rate : 272 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 628 KiB (1%)
    Language : English
    Encoded date : UTC 2019-09-25 14:26:52
    Tagged date : UTC 2019-09-25 14:26:52
    Francois Pénzes replied 7 years ago 2 Members · 1 Reply
  • Francois Pénzes
    September 25, 2019 at 7:20 pm
    Hi Andrew
    You may have more luck in using the official Magix Forum for Movie Studio
    This forum is more tuned for Vegas Pro users. (sorry about the bold character, I can’t get rid of it…)
    https://www.vegascreativesoftware.info/us/vegas-movie-studio-forum/
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
