Activity Forums Adobe After Effects Rendering. From a previous post.
  • Rendering. From a previous post.
    Posted by Rdub on July 10, 2009 at 9:12 pm
    Getting this error when rendering.
    After Effects Error:PhotoShop file format error-out of memory
    (-108)
    (45:35)
    XP Pro with 4 gig ram.
    Recognize this error?
    Also, the render screen shows 12% of 3 GB Ram being used. Shouldn’t AE be utilizing more than 12% of RAM? I have 4 GB of ram.
    Adolfo Rozenfeld replied 17 years, 2 months ago 3 Members · 10 Replies
  • 10 Replies
  • Todd Kopriva
    July 10, 2009 at 10:02 pm
    Are you using a PSD file with a 3D object layer?
    Have you updated to After Effects CS4 (9.0.2)? The 9.0.1 and 9.0.2 updates have addressed some erros that look like this.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Rdub
    July 10, 2009 at 10:15 pm
    Updating now. Should know if it helps in about 45 mins.
  • Rdub
    July 10, 2009 at 10:29 pm
    If nothing else works I may have to upgrade the computer. I can’t render for 20+ hours and then notice changes or continue to get errors. As a reminder, I have an XP Pro machine. 4 GB Ram. One internal drive and one External drive. Core 2 Quad CPU. Radeon HD 2600 Pro video card. If I was to build a PC for After Effects from the ground up what should I do differently.
  • Rdub
    July 10, 2009 at 11:19 pm
    Now that I have updated AE my render time is 30+ hours. How can anyone work with a render time like that?
  • Adolfo Rozenfeld
    July 11, 2009 at 5:11 am
    How long is your composition in time?
    What kind of material/operations do you have in your Comp? As Todd asked, are you using Photoshop 3D? If you use the highest rendering options, you can get some serious rendering time.
    Don’t worry about the 12 per cent used of 2.0 GB used in the splash screen. That’s a message before the application is operational.
    XP 32 is severely challenged in memory handling, and yes, because of this AE can’t take advantage of the 4 GB in your machine. If you have a multi-core computer, you may want to consider upgrading to Vista 64 (or wait for Win 7). If you have a dual core machine, 4 GB will be fine. If you have a quad core processor, you want more than that to take advantage of multiprocessing.
    Adolfo Rozenfeld · Adobe
  • Rdub
    July 11, 2009 at 3:57 pm
    I’m using jpg images only. I guess I’m not familiar with PhotoShop 3D. Sorry. I have a core 2 quad processor. With XP Pro, how can I use more than 4 Gig of Ram?
  • Rdub
    July 11, 2009 at 4:55 pm
    The comp consists of a 2D layer with Trapcode Particle and a source layer which is a comp of 300+ images. Also a camera for scanning from left to right.
  • Adolfo Rozenfeld
    July 11, 2009 at 9:44 pm
    What’s the time length of the Comp?
  • Rdub
    July 12, 2009 at 2:44 am
    10 minutes. Tried it at 5 minutes. Not much better.
  • Adolfo Rozenfeld
    July 12, 2009 at 2:52 am
    What do you mean with “a source layer which is a comp of 300+ images”?
