Activity Forums Adobe After Effects Rendering Frame Numbers on each frame of exported video.
  • Rendering Frame Numbers on each frame of exported video.
    Posted by Joey Campbell on October 20, 2022 at 4:58 pm
    Hi – is it possible to export footage from AFX so that a corresponding frame number is displayed for every single frame of video. For example in the bottom right corner I would like 01 displayed for the first frame and 02 for the second frame and …45 displayed for the 45th frame and so on and so on. Is there a setting or plugin to enable this or does it have to be coded using actions. If the latter, can anyone help ?
    Joey Campbell replied 3 years, 10 months ago 2 Members · 2 Replies
  • Chris Voelz
    October 20, 2022 at 7:23 pm
    Couple of options. You can render out to or compress with Media Encoder and in the Export Settings under the Effects tab there is a Timecode Overlay toggle. Or you could create a text layer and add the expression to the Source Text.
    timeToFrames()
  • Joey Campbell
    October 20, 2022 at 8:14 pm
    Thanks so much
