Activity Forums Adobe After Effects Rendering for web and video
  • Rendering for web and video
    Posted by Sanjay Chalisey on November 1, 2006 at 9:10 am
    Have a problem in that I’ve created a comp which will eventualloy be produced into an MPEG-2 video and also an animated gif sequence.
    All is fine expect for the rendering aspect of the animated gif.
    When I render the comp, the animated gif looks bad – especially the glow filter which is a part of the comp.
    My question is: what are the best rendering variables to apply when working for the web?
    Also, the glow; should this be based on an alpha channel or a colour channel?
    Any help would be greatly appreciated.
    Thanks.
    Sanjay Chalisey replied 19 years, 10 months ago 2 Members · 2 Replies
  • Mylenium
    November 1, 2006 at 10:01 am
    Do not render GIFs from within AE. Render a MOV and import that into ImageReady. You have much more control there and everything will certainly look a lot better even at the default settings.
    Mylenium
    [Pour Myl
  • Sanjay Chalisey
    November 1, 2006 at 10:42 am
    Thanks Mylenium,
    Works brilliantly. Hadn’t realised that you could import Quicktime files into Image Ready.
    Amazing what you learn!
    Much appreciated.
