Rendering for Quicktime…
Posted by Owen Myers on July 13, 2009 at 8:04 amI have a composer that works in ProTools. He is requiring for me to give him my Vegas Pro 8.0c project to him in a Quicktime format. I tried to render with the default Quicktime settings, and pretty instantly it tells me it’s not a supported format. I then went into the settings where it says video format. I selected DV/DVC Pro NTSC and set it for Progressive.
It seems to be going forward now, but I’m going to bed and it says that it has 2 hours to go. I figured I will probably get the correct instructions from someone at Creative Cow and they will be waiting for me in the morning.
Please help.
Thank you!
Owen
Edgardo Rodriguez replied 17 years, 2 months ago 4 Members · 9 Replies -
Steve Rhoden
July 13, 2009 at 12:42 pmYou can easily render out the project in the quicktime
format using the Animation codec or Photo-jpeg with
quality set at 95%…..Nothing complex.Steve Rhoden
(Cow Leader)
Creative Arts Director and Film Maker.
Project Samples at:
http://www.youtube.com/hentys -
Owen Myers
July 13, 2009 at 4:46 pmYou’re the man.
Thank you.
My 5 minute project took 7 hours with the mpeg-2 setting. That in itself was crazy to me. Even after that the image quality sucked.
Have a great day!
Owen Myers
July 13, 2009 at 6:29 pmThanks again for the advice on the settings for Quicktime Rendering.
I used the Animation Codec and just like mpeg-2 it is taking 7 hours to render a 5 minute project. And that’s on my fast quad core desktop. My slower dual core laptop wants to take 14 hours. How do I speed up this process? Or is there no speeding it up?
Thank you for any further assistance.
Owen
Mike Kujbida
July 13, 2009 at 6:44 pmWhat’s your source footage?
How many and what kind of FX did you use? -
Owen Myers
July 14, 2009 at 12:14 amThe source footage is from a Sony HDRFX7. Mini DV. The full HD tapes.
No FX. A thousand little cuts but nothing special.Now I’m over the 7 hour thing, I just want the end result to be usable in ProTools.
– My first attempt, I set the video format to mpeg-2 in the Quicktime render. After I tried that, I tried to use just the rendered files in ProTools. No dice. I tried to render that file to DVD in Architect. It won’t even play in the Quicktime on my PC.
– Steve from Creative Cow told me to try the Animation or Photo jpeg Codec instead of mpeg-2.
– Is one better than the other?
– Do I just copy the rendered files onto a disc for ProTools or do I then render them to a DVD in Architect.However I need to do it, I need a Quicktime movie in the end.
Thank you for any help!
Owen
Mike Kujbida
July 14, 2009 at 1:02 am“Is one better than the other?”
Render using both of Steve’s suggestions.
It’s a short file so it should go quickly.“Do I just copy the rendered files onto a disc for ProTools or do I then render them to a DVD in Architect.”
There’s no need to render them to a DVD.
Just copy them to a disc the way they are. -
Steve Rhoden
July 14, 2009 at 3:22 amWhat rendering time are you getting with either of my
recommendations?
You can choose either one, and you’ll get good result either way.
and when you are done, just save it as file on a disc (data disc)
as Mike said….then just hand that over to your Pro-tools guys.Steve Rhoden
(Cow Leader)
Project Samples at:
Owen Myers
July 14, 2009 at 4:47 pmWith Animation, the rendering time for a 5 minute short was 10 hours.
With Photo, it was 7.
To render a standard mpeg-2 for architect takes 40 minutes.There are a lot of visual cuts, because of all the sound cuts (ex. to drop a floor creak and insert roomtone). But nothing special at all. 1 video track. 9 audio tracks.
I don’t know what takes so long, but I guess it is what it is.
Thank you for your help!
Owen
