Rendering for DVD
Posted by Frenchie29 on September 25, 2007 at 1:21 amHi I’ve posted the same question a few weeks ago but can’t find that post. Anyways I would like to know how can I render for DVD? It’s a very short video (6 minutes) so I can use the highest quality setting
Terje A. bergesen replied 18 years, 11 months ago 5 Members · 9 Replies -
Jacob Hobbs
September 25, 2007 at 1:53 amRender As….
Select Mainconcept MPEG-2
DVD NTSC template (For USA)
DVD PAL (for other countries)If you want to use higher bitrate, select “custom” button, Video tab and type in your bit rates.
Kolbjørn Hoseth larssen
September 25, 2007 at 5:44 amHi!
Use Constant bit rate. And choose the highest available: 9800. -
Terje A. bergesen
September 25, 2007 at 3:01 pm9800 will, when you add audio, be too high for many DVD players.
Mike Kujbida
September 26, 2007 at 3:11 amHe means that, if you render your video at 9,800,800 (maximum allowable), you won’t have any room left for the audio portion of your project.
Jacob Hobbs
September 26, 2007 at 9:38 pmAll DVD players that have the “DVD Logo” should be compliant up to 10.08 Mbps (10080 kbps),(Video+Audio+subs). If the player can’t sustain this bitrate on pressed or recordable discs, it is not compliant. And it shouldn’t have the DVD Logo, IMO. Personally, I would replace the junk DVD player, if it had trouble sustaining these rates.
I always use two-pass variable bitrate with 9800kb/s max + 256kb audio. This gives 10056kb/s, which is just under the maximum allowed.
Mike Kujbida
September 26, 2007 at 10:10 pm[Wile_E] “I always use two-pass variable bitrate with 9800kb/s max + 256kb audio. This gives 10056kb/s, which is just under the maximum allowed.”
The problem is that pressed discs are OK at that high a bit rate but I personally would never go that high on any burning job, even though I stick to Taiyo-Yuden and Verbatim media exclusively.
My feeling (and that of numerous other posters) is that that’s just asking for problems. -
Terje A. bergesen
September 27, 2007 at 6:58 amMike is absolutely correct. The reflectivity etc of a burned disk is significantly lower than of a pressed disk, and it is therefore more problematic for a player to read. If you burn disks at max bitrate, you are guaranteed to run into problems with a number of DVD players. Even if these play max bitrate pressed DVDs fine.
We may like it or not, but going far above a 9M or so in total bitrate with burned disks is just asking for trouble.
