Activity › Forums › Adobe After Effects › Rendering for Avid Thunder
  • Rendering for Avid Thunder
    Posted by Andrew Sprout on November 17, 2009 at 3:50 am
    At college, we use Avid Thunder for our still store.
    Using AfterEffects I have previously created full screen QuickTime movies that run on it just fine.
    What doesn’t work are QuickTime movies with Alpha channels. The Thunder notices it has a key and enables it, but the video comes out distorted. When the key is disabled, the video plays fine (but it’s obviously missing its key).
    Any ideas on how to fix this? Or, failing that, how to make the Thunder play videos out of two channels that match each other, so that one can be the key and the other the source?
    Andrew Sprout replied 16 years, 10 months ago 2 Members · 2 Replies
  • Gary Hazen
    November 17, 2009 at 1:16 pm
    What codec are you using?
    The old Thunder DDR’s utilized the Pinnacle DV codec for files with embedded alpha channels.
  • Andrew Sprout
    November 17, 2009 at 2:14 pm
    I’ll have to see if there is support for that in our Thunder system. I’ve been using Quicktime Animation movies, but do have a feeling a different codec would be of use (just didn’t know which one to use).
    Any idea on which Pinnacle DV codec it is that supports alpha channels? After a quick Google, haven’t found anything super useful yet.
    Respectfully,
    Phillip Platz
