Activity Forums Adobe After Effects Rendering for a kiosk
  • Rendering for a kiosk
    Posted by Malcolm Desoto on January 15, 2019 at 5:22 pm
    This is kind of a weird one. I’m trying to output some simple animation in a .wmv format.
    I have the spec sheet which says the dimensions should be 1152×864, however; when the file is played on the screen, the graphic is cropped.
    Anyone have any ideas on how I might be able to correct this? I’m also attempting to contact the sign company, but thought I’d check here as well…
    runawaykitee.blogspot.com
    “The secret to creativity is knowing how to hide your sources.” –Albert Einstein
    Jeff Kay replied 7 years, 8 months ago 4 Members · 4 Replies
  • Jeff Kay
    January 15, 2019 at 6:57 pm
    According to the sign controller it is 168×96 not 1152×864 (I can see the pixels it most certainly is not 1152×864). Looks like the sign controller is set to scale to fill, which is why you are getting cropping.
    Export a copy at 168×96 and it should play correctly.
  • Kalleheikki Kannisto
    January 15, 2019 at 6:59 pm
    Looking at the spec sheet the image matrix is 7:4 while the “display setting” is 4:3. My conclusion based on the result would be that 7:4 ratio image is what they are actually showing.
    Senior Graphic Designer
  • Eric Santiago
    January 15, 2019 at 8:00 pm
    I’ve run into specific digital signage systems that give you the odd pixel sizes.
    Some I got away with doubling the actual number and their systems auto-filled and felt it was better looking that if I sent the actual 1:1 size.
    Maybe its just in my head 🙂
  • Jeff Kay
    January 15, 2019 at 9:23 pm
    Wouldn’t surprise me. There are a lot of digital signs that are. . . just not set up correctly. Seen several that use a standard video resolution output that is stretched to the size of the board.
    I’m 90% positive that the 1152×864 4:3 resolution is the desktop resolution of the device that is playing the content, which is relatively common for something running headless.
