Activity Forums Adobe After Effects rendering footage that is 16:9 ends up 4:3
  • rendering footage that is 16:9 ends up 4:3
    Posted by Gino Guarnere on March 1, 2006 at 1:17 pm
    Hey all,
    I have a comp setup using preset HDV 1080/29.97, width is 1440 x 1080, PAR is HDV1080 and Frame Rate is 29097. Resolution is “full.”
    It’s just a text effect.
    A few questions about rendering:
    I’ve tried to render this 2 second clip in all sorts of varieties, using a number of settings, including the “stretch” checkbox. Why is my final output clearly a 4:3 quicktime?
    My render settings:
    Quality = best
    resolution =full
    size 1440 x 1080
    Use OpenGL Renderer = checked (Open GL support)
    Time sampling, I’ve made no chages
    Frame Rate: Use Comp’s frame rate (29.97)
    OUTPUT MODULE SETTINGS
    Format = quick time movie
    video output > Format Options > Animation
    Stretch = unchecked, but “Lock Aspect ration to 4:3” is checked and grayed out. I’ve tried checking off “Stretch” and then unchecking the “Lock Aspect Ration to 4:3” but have gotten the same output in either case
    Crop is unchecked
    Audio output is unchecked as there is no audio.
    Where am I going wrong? I end up with a 4:3 movie no matter what I try. I need the footage to stay 16:9 so I can bring it into FCP, where all my footage is 16:9.
    Thank you. I hope this made sense.
    WB
    Sam Moulton replied 20 years, 6 months ago 3 Members · 4 Replies
  • Gino Guarnere
    March 1, 2006 at 1:20 pm
    I think I figured it out.
    Let me guess: is 1440 x 1080 a 4:3 PAR?
  • Gino Guarnere
    March 1, 2006 at 1:24 pm
    Ok, So I check off “stretch” in Output Module Settings, then change the width to 1920 and height to 1080, which gives me a checkbox that says “Lock Aspect Ratio to 16:9”
    How do I make that a “permanent” setting so it always outputs that way?
    Thanks, guys and dolls.
    WB
  • Steve Roberts
    March 1, 2006 at 1:28 pm
    Search the help for “templates”.
  • Sam Moulton
    March 1, 2006 at 2:12 pm
    1440 X 1080 is a 4 X 3 ratio of pixels. when you throw in the pixel ratio then you get 16 by 9 picture.
    If your ouptut or capture from final cut is 1440 X 1080, then your render from After effects should be the same size. fc should take care of the par.
