Activity › Forums › Apple Final Cut Pro Legacy › Rendering factors
  • Rendering factors
    Posted by Jack Fox on January 27, 2007 at 10:19 pm
    I captured video from my dvx100 in 24p as I have done many times before. Sometimes, when I drop a segment into a 23.98 time line it requires rendering even though there are no effects, and it requires rendering even though I set the RT to low quality. I am running, no other programs, the latest Tiger, dual 2.0 G5 and Final Cut 4.5. What can cause some clips, before any editing, to require rendering an others not? I’ve even tried another computer to see if it was the something other than the clip. Please advise.
    jmf
    Jack Fox replied 19 years, 8 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    January 28, 2007 at 2:28 pm
    Only thing I can think of is that the properites of the clip don’t match the properties of the sequence… did you not remove the pulldown? That would explain it for example… Look at the properties of the clip by selecting it in the Browser and typeing cmd+9…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jack Fox
    January 28, 2007 at 4:46 pm
    What should I be looking for? I see the vid rate is 29.97 in the clip and the sequence is 23.98.
    jmf
  • Jack Fox
    January 29, 2007 at 12:17 am
    Okay, Jerry if finally sunk in. I capture the footage set to “DV NTSC 48 kHz” rather than “DV NTSC 48 kHz Advance (2:3:3:2)” Pulldown. Do I need to recapture?
    jmf
