Activity Forums VEGAS Pro Rendering error; looks like an interlace problem.
  • Rendering error; looks like an interlace problem.
    Posted by Phillip Grey on September 15, 2008 at 8:20 pm
    So, I’ve been using the following settings and then I use Event Pan/Crop and Match Output Aspect to emulate the cinemascope ratio.
    It works great in editing, in terms of preview video. But then I render it (as .mov or .avi) and get this ugly ole’ error:
    Since field order has been set to progressive, I don’t understand what’s going wrong. And again, it all looks fine during editing. It’s only when rendered does this interlace issue arise.
    I haven’t rendered to MPEG and burned to DVD yet to see what happens then. I did render to tape and got the same problem, though. I hope there’s gonna be an easy solution to this…anyone know what I’ve obviously done wrong?
    Chris Young replied 17 years, 11 months ago 4 Members · 3 Replies
  • Steve Rhoden
    September 15, 2008 at 10:33 pm
    When you want to achieve proper de-interlacing results, a de-interlacing filter is a must….There are a some really
    excellent ones out there, but they are as plugins for other hosts.
    The best free one i could recommend you try is “smart deinterlace”
    at https://www.mikecrash.com/modules.php?name=Downloads&d_op=viewdownload&cid=13
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • Theo Van laar
    September 15, 2008 at 10:47 pm
    Philp,
    In your project properties, you set as deinterlace method NONE. Wouldn’t it help to put it on INTERPOLATE FIELDS (in case of a high-motion video)?
    Theo
  • Chris Young
    September 21, 2008 at 12:39 pm
    Try setting you project properties to ‘best’ and on the timeline set your clip properties to ‘reduce interlace flicker’, under right click menu ‘switches’ . Render out sixty seconds or so and see if this fixes the problem. Most likely it will.
    Chris Young
    CYV Productions
    Sydney
