Activity › Forums › Adobe Premiere Pro › Rendering error in Pro 2
  • Rendering error in Pro 2
    Posted by Adam Clements on August 21, 2008 at 12:13 pm
    I have a particular sequence in Pro 2 ehich is giving me some jip when I try to render.
    As soon as I hit enter, it comes up with:
    [Video Preview Error]
    Error compiling movie.
    Unknown Error.
    I have had this a couple of times, but when I close and re-open the project it works fine, but this particular sequence doesn’t seem to right itself.
    There are no extravagent effects to render – some basic audio effects, and brightness/contrast, slow-motion or dual-layers on the video tracks… It has managed far more complicated situations with ease.
    Any idea what the problem could be?
    Adam Clements
    Adam Clements replied 18 years, 1 month ago 3 Members · 3 Replies
  • Mike Cohen
    August 21, 2008 at 7:42 pm
    try rendering a portion of the sequence
    try exporting the whole sequence or a portion.
    You may need to use trial and error to find the clip that is causing a problem.
    Alternatively, make a new project and import the problem project into the new project.
    Premiere’s vague error messages can be frustrating – i have posted my fair share of questions about these over the years.
  • Dustin Brown
    August 21, 2008 at 10:13 pm
    If, by chance, the clip that’s giving you beef is a TGA sequence, then I would say that is your problem. I’ve had nothing but headaches getting Premiere to render TGA sequences. Since the day I switched to using 32-bit PNG sequences, life has been much easier.
    -Dustin
  • Adam Clements
    August 22, 2008 at 12:26 pm
    Great,
    I do actually have a targa sequence in this section, though if it is the beef-laden clip in question, it has affected the project as a whole because I am getting these errors for any part of the two master squences in the project.
    I will try removing them and give it another go.
    Adam
