Activity Forums Adobe Premiere Pro Rendering Dynamically linked AE Comps in Premiere Timeline
  • Rendering Dynamically linked AE Comps in Premiere Timeline
    Posted by Symeon Platts on August 12, 2014 at 8:45 pm
    For a few months now, I have tolerated a problem I haven’t experienced the past. Many of the projects I work on require 5-15 AE Comps in my Premiere timeline. Each composition consists of very simple animations.
    As of late, Premiere can hardly render them, with renders taking 10 minutes or more for a 15 second comp of a dotted line with a trim animation. When I attempt to render the dynamically linked comp in premiere, it will often stick on 0.1% for 1-5 minutes. If it does finally start rendering, it can take anywhere from 5-15 minutes.
    Are there any settings in Premiere or After Effects that could be causing this? Is this normal behavior? Or should I be expecting much quicker render times for such a simple animation; even if it is dynamically linked.
    Specs:
    iMac
    27-inch, Late 2013
    Processor 3.5 GHz Intel Core i7
    Memory 32 GB 1600 MHz DDR3
    Graphics NVIDIA GeForce GTX 780M 4096 MB
    Software OS X 10.9.3 (13D65)
    Adobe Premiere Pro CC
    2014.0.1 Release
    8.0.1(21) Build
    Adobe After Effects CC
    2014.0.2 Release
    Version 13.0.2.3
    Sequence Settings:
    David Seay replied 12 years, 1 month ago 2 Members · 1 Reply
  • David Seay
    August 19, 2014 at 6:40 pm
    I have the same problem and use an Imac exactly like yours. The one and only thing I have found that helps is to render the AE comps (be sure and check the “include project link”). Put those rendered clips in the timeline and then Premiere exports it lightning fast. If you have the project link box checked, you can use the “edit original” function in Premiere and it launches that AE comp for further editing. Maybe it’s a bug or something, but a file is a file is a file within the Adobe environment and should render the same no matter where it is. Hope we get this worked out
    TV- It’s why Kennedy beat Nixon
    david seay
    https://www.davidseayproductions.com
