Activity Forums Apple Final Cut Pro Legacy Rendering DVD makes clips out of order
  • Rendering DVD makes clips out of order
    Posted by Mike Porter on July 31, 2011 at 7:21 am
    I have a apple quad 8 core intel tower running final cut 6 and OSX5.8
    I am having a very strange problem which is: if I put my clips together and add my effects transitions it all looks good and works fine until I render everything to make a DVD, after I render everything the clips are all out of order and so are the effects (not the way it looked before I rendered it) in short, if I put it together and play it on my timeline for viewing before rendering it all looks fine but once I render it it is not the same as before it was rendered, I have never had this problem before, can someone tell me what is causing this and how can I correct this? Thanks, Mike
    Steve Eisen replied 15 years, 1 month ago 3 Members · 2 Replies
  • Jerry Hofmann
    July 31, 2011 at 1:11 pm
    Post the properties of the source clips. ProREs? DV? or?
    Also post the sequence settings you’re using.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Steve Eisen
    July 31, 2011 at 2:41 pm
    Trash your render files and re render.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
