rendering dv-avi for blu-ray
I’ve got some DV AVI files I captured from my dv cam, and I’d like to put these on blu-ray so I can keep the high quality and bitrate (not because I expect the resolution to be higher or anything like that). I’d like it to be able to play on any regular blu-ray player. The AVI files have a bitrate of roughly 30mbps I believe.
After I imported everything in sony vegas, I rendered the video and audio seperately. I chose the “sony avc” type, chose a blu-ray template (Blu-ray 1920×1080-60p, 16 Mbps I believe), and then used the customize button to make changes to fit my file. The changes I made were to change the frame size to 720×480, raise the bitrate to 20Mbps and that was it (the framrate was already NTSC)
The questions I have are
1) The resulting file was of decent quality, but the motion looked very jittery compared to the source file were it is extremely smooth. Is there something obvious that I did wrong to produce that?
2)I thought the max bitrate for blu-ray was around 40mbps or something? I learned recently with dvd that although the max is 9.9mbps, 8 is the highst ‘safe’ bitrate for most players. So I know I may not be able to hit max, but 50% of max seems fairly low as a limit. Why can’t I set something higher than that?Some other info that may be relevant- my project template is NTSC DV Widescreen (720×480), full-resolution rendering quality is set to “best”, motion blur is Gaussian, and deinterlace method is Bland Fields”
I also have “adjust source media to better match…” checked.
