Activity Forums Apple Final Cut Pro Legacy rendering dissappears video on timeline and viewer
  • rendering dissappears video on timeline and viewer
    Posted by Keith Rivers on May 19, 2009 at 8:20 am
    I’m completely baffled…
    The video source on my timeline are 3 frame sizes cropped equally to display a left middle and right section, when I render the green out for an actualized playback the right section of video disappears, but when it’s un-rendered its play is visible.
    What is causing this to happen?
    frame rate – 2997
    resolution – 1280×1080
    audio – ST
    keith
    youtube.com/krfilms
    Todd Reid replied 17 years, 4 months ago 2 Members · 1 Reply
  • Todd Reid
    May 20, 2009 at 1:28 am
    That’s a weird one…
    first thing that pops into my mind is maybe a corrupted render (sequence or project).
    Depending on your deadline, length of project, I would suggest deleting all your render files (use either render manager, or manually navigate to your proper render folder for that project and delete everything.
    then, you will obviously need to re-render everything. See that works. If not, do the basic troubleshooting tips…repair permissions, trash fcp preferences. open new project and copy/paste all items into it, same concept for the sequence. create new, then copy/paste into it.
    That is an obvious snafu, as if you can see it, (in a still) unrendered, then once rendered you should see it too (playing in real time).
    hope this helps
    you just have some funk you have to shake off, then you should be golden.
    Todd Reid
    Senior Editor
    Digitized Media, Inc.
