Activity Forums Maxon Cinema 4D RENDERING DEPTH IN MULTIPASS
  • RENDERING DEPTH IN MULTIPASS
    Posted by Carlos Angulo on January 11, 2007 at 11:48 pm
    Here is a question about multi-pass rendering.
    Im tryng to render separately the depth channel in multipass, when I see the depth channel in the picture viewer looks perfect, but if I try to open a depth frame in photoshop, I get a full black frame, therefore I cant assign blur values in after effects. Can anybody tell me what I’m doing wrong?
    Mylenium replied 19 years, 7 months ago 3 Members · 2 Replies
  • Brian Jones
    January 12, 2007 at 3:28 am
    if you saved a depth channel only image you get black because you didn’t include any image layers but the depth is still there in the alpha channel (assuming you saved as a .psd)
  • Mylenium
    January 12, 2007 at 6:15 am
    Like Brian said, if you choose PSD as format, some passes will get saved in the channels rather than as extra layers. A bit useless for AE, so you may wish to use separate images for each pass (disable “Save Multilayer file”).
    Mylenium
    [Pour Myl
