Activity Forums VEGAS Pro Rendering de-pixels my video
  • Rendering de-pixels my video
    Posted by Stefan Schramm on February 7, 2017 at 9:44 am
    Hi guys,
    I often need to create videos where a face is pixelated. Looks great in the timeline, but after rendering the file, the image is nearly normal with just a tiny bit of pixelating.
    Any idea what’s going on?
    Stefan
    Vegas 12, Windows 7 Professional
    Stefan Schramm replied 9 years, 7 months ago 2 Members · 2 Replies
  • László Kovács
    February 7, 2017 at 5:39 pm
    Hi Stefan,
    I can’t remember I used a pixelate effect any time, but used other effects. Some of the effects render dependant on preview (render) quality. Sharpen is one of these effects.
    If you set preview to best/full, theoretically you should see exatcly what you will see when rendered, while with simply
    “preview/full” not necessarily.
    So this is just a shot in the dark, but maybe set preview to best/full, and adjust the effects properties so.
    Other question, that you render to the same resolution as it is the project properties?
    Best regards
    László Kovács
  • Stefan Schramm
    February 14, 2017 at 4:50 pm
    Hi László,
    I’ll give that a try. When I rendered again the other day, I noticed quite a bit of difference between Vegas 9 and 12. We usually edit on 12, but sometimes we need to edit in 9, because 12 chokes on the files by a certain client.
    I think I need to add extra large pixels because when the image is scaled to a smaller output frame size, some of the blurring effect disappears. It doesn’t happen as much ith v12.
    Stefan
