Activity Forums Apple Final Cut Pro rendering compund clips
  • rendering compund clips
    Posted by Julian Bowman on March 22, 2013 at 10:26 am
    I may be wrong but it appears that if i break a project into sections, edit each in a timeline, compound clip the sequences and then pop them in a play all timeline, that when I render one of the initial sequences it doesn’t render the compound clip version in the timeline. This also appears visa versa. is this correct?
    Cheers
    David Battistella replied 13 years, 1 month ago 2 Members · 1 Reply
  • David Battistella
    March 22, 2013 at 1:47 pm
    Check your sequence render settings to make sure you are rendering to the quality that matches your output quality preferences.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://www.davidbattistella.com
