Activity Forums Adobe After Effects Rendering = color problems. Washed out.
  • Rendering = color problems. Washed out.
    Posted by Dirk d. Lopez on January 13, 2010 at 9:26 pm
    Hello, my colors look perfect when I am animating and previewing in After Effects CS3, but as soon as I render the comp out, the colors change and wash out my animations. To some it may seem subtle but to me its really annoying.
    I have already tried: turning on/off color management, trash my preferences, render with animation codec and JPEG sequence, and changing the comps from 8, 16, 32. Nothing seems to work. Whats going on?
    Sample of whats going on (the top is correct, the bottom is washed out):
    Thanks for the help
    James Dillon replied 10 years, 10 months ago 4 Members · 5 Replies
  • Scott Novasic
    January 13, 2010 at 11:00 pm
    not sure if this helps, but it appears that you have an extremely subtle radial blend in the background. Those type of subtle blends ten to be more difficult to get smoooth. Notice in the top image there is some banding and an attempt at a blend. The bottom image seems to have ‘given up’ on even trying to replicate that blend and is just a lighter solid grey. The key lies in that blend and if you truly need it or not. Otherwise, a higher bit depth should help. Its so subltle I might just eliminate it.
    Hope my observation helps some….
    Scott
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Dean Sensui
    January 14, 2010 at 6:28 am
    I don’t know if you’re working on a Mac but this is what I do:
    — Go into Project Settings.
    — Set “Working Space” to “none”.
    — “Linearize Working Space” is “off”.
    — “Blend colors using 1.0 Gamma” and “Match Legacy After Effects QuickTime Gamma Adjustments” are “on”.
    Dean Sensui — Hawaii Goes Fishing
  • Dirk d. Lopez
    January 15, 2010 at 4:30 pm
    Thanks everyone for the help and suggestions! Unfortunately none of the worked for me.
    But I did try export through the ProRes codec and it worked great. Not sure why though considering, at least I thought, that the Animation Codec was the highest quality. Anyways ProRes will work, until I’m screwed and need to render out a clip with an alpha channel since its not supported with the ProRes Codec.
  • Dirk d. Lopez
    January 18, 2010 at 7:46 pm
    Dave, thanks for the link to that article. It did seem to help. Basically what it led me to do was use Color Management in AFX upon rendering. I tried out a few different options: HDTV, Apple, Adobe, etc… and it seems to be closer to the original than the Animation codec left alone.
    Thanks for your help with this issue.
  • James Dillon
    November 27, 2015 at 10:52 am
    Can you please tell what exactly need to be done if there is a lot of colors mismatching after rendering from After Effects.
    I have tried to render a composition with many different settings and I have even adjusted the project settings like gamma and all but seems that nothing is working right now for me .
    I look forward for your reply . Thanks
