Activity Forums VEGAS Pro rendering blank frame with Sony Vegas 13
  • rendering blank frame with Sony Vegas 13
    Posted by James Redmond on November 25, 2014 at 5:20 pm
    Hi!
    I just upgraded to a new computer I built:
    Asus x99 Deluxe
    i7 5820k
    32 gig ram DDR4
    GTX 970 graphics
    win 7 Pro
    I built it to speed up my rendering times. When I need to render I generally have lot of files – like this time.
    Currently I have a project with 15 DVDs, going from Canon MFX format to mpg format.
    Done this a bunch without any problems with an older Sandy Bridge i7 computer and Sony Vegas 12.
    What is going on is that I’m getting a blank or black frame every so often. It is random. In a 8 minute section I counted 32 blank frame! Not acceptable.
    Not sure if this is Vegas 13 or a computer issue. I just rendered the same section on the older computer with Vegas 12 and I could see no problems.
    Any ideas of where the problem is?
    Thanks in advance. James
    James Redmond
    Dynamic Videos, Inc.
    Rogers, AR USA
    Dan Mccloy replied 11 years, 7 months ago 4 Members · 4 Replies
  • Graham Bernard
    November 26, 2014 at 6:31 am
    [James Redmond] “What is going on is that I’m getting a blank or black frame every so often. It is random. In a 8 minute section I counted 32 blank frame! Not acceptable.”
    James, count me in too. I use my Canon MXF Media. Is yours Interlace?
    I was at the back-end of a Deadline project that I had to deliver in DVD and MP4. MP4, no issue. But the MPEG2, from the MainConcept Template, I ended up with a FOREST of Black frame Markers. Something has happened.
    OK, my only remedy was to create a Lossless Lagarith AVI DI and do the MPEG2 from that.
    Irony? I didn’t NEED to produce the DVD, ‘cos the laptop from which my videos were shown from didn’t posses a DVD/CD Player . . . . .
    Using mine and your experience I’m wanting to report this to SCS.
    Oh, and before we get comments on any of this, here’s what I did for a Control Test:
    * Scrutinized the Original and EVent footage for any Frame issues – none!
    * NO Fx-ing.
    * GPU on or OFF made no difference
    * Various BitRates and combinations of Max<>AVg<>Min
    In fact none of the “usual” suspects would make any difference.
    So James, thanks for sharing.
    Grazie
  • James Redmond
    November 26, 2014 at 3:21 pm
    Graham, It is Progressive, but Vegas sees it as interlaced.
    Yesterday I upgraded to the latest build of Vegas Pro 13, build 428. Basically same result. I even tried changing the rendering template to 2 pass, progressive, etc. Still drop frames!
    However when I got to my other computer with Vegas Pro 12, no dropped frames!
    And since you having the same problem it must be Vegas 13.
    Thanks for verifying what I’m experiencing.
    I guess the only real option is to submit a support ticket and wait for them to identify and fix the problem. James
    James Redmond
    Rogers, AR USA
  • Ken Bennett
    November 26, 2014 at 5:57 pm
    I had to go back to V12 due to this problem. V13 would start to inject black frames (almost like a flashing effect) on long projects. Same project in V12 rendered fine. Has to be something wrong with the V13 render engine.
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
  • Dan Mccloy
    February 4, 2015 at 2:14 am
    Having the same issue. Driving me nuts. Any idea if Sony has addressed this? I can find almost no info on it.
