Activity › Forums › VEGAS Pro › rendering between markers
  • rendering between markers
    Posted by John Baum on November 16, 2005 at 7:34 pm
    Is there a way, with scripting or otherwise, to automate rendering segments between markers as seperate files. Or maybe render each clip on a timeline as a seperate file?
    Gary Kleiner replied 20 years, 10 months ago 3 Members · 3 Replies
  • Edward Troxel
    November 16, 2005 at 8:40 pm
    Yes. I use Excalibur when I want to render regions. It can also create regions around events if they don’t already exist. So, yes, it can be done via scripts. Do some searching and you may even find a free one that will handle your needs. For example, there’s a “BatchRenderGUI” script that will handle regions. I’d be happy to e-mail it to you.
    Edward Troxel
    JETDV Scripts
  • John Baum
    November 16, 2005 at 9:18 pm
    Never found a use for regions before but this is a good one as it is a task I have to do every few months.Thanks for the tip!
  • Gary Kleiner
    November 16, 2005 at 9:24 pm
    [ghobii] “Never found a use for regions before but this”
    I use them contantly to make myself notes about changes or fixes I have to make throughout the project.
    Gary
