Activity Forums Apple Final Cut Pro Legacy rendering before sending to compressor?
  • rendering before sending to compressor?
    Posted by Manuela Corbari on March 4, 2009 at 11:56 pm
    Hi guys
    I was just wondering..
    do i need to render my sequence before i export it with compressor, or is it better to delete all the rendered files and send it straight to compressor?
    i’m working with HD1080i50 footage, with some color corrector and smoothcam filters
    Manuela
    David Roth weiss replied 17 years, 6 months ago 2 Members · 3 Replies
  • David Roth weiss
    March 5, 2009 at 12:03 am
    For sure you should render, unless you have lots and lots of time on your hands to waste.
    Furthermore, you should consider exporting first before bring to Compressor, using Export>>Quicktime Movie at current settings (don’t check the re-render all frames box). This way you make a one to one copy of your timeline that is identical in every way, and you can continue editing in FCP while Compressor chugs away.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Manuela Corbari
    March 5, 2009 at 12:21 am
    will the end result be the same though (quality wise), with these 3 methods?
    -send to compressor without rendering
    -rendering first (it takes hours anyway!!) and then sending to compressor
    -export as QT with current settings and then compressor
    there’s always something new to know..
    Thank u
    Manuela
  • David Roth weiss
    March 5, 2009 at 12:58 am
    Well, there’s any easy answer to that one and a difficult answer too…
    In a nutshell you are far less likely to encounter difficulties (such as black frames or missing audio) by rendering first before exporting with Compressor or just out of FCP.
    Regarding quality, essentially the same in all three, except when encoding to MPEG2 using 2-pass method rather than constant bitrate method. That sets different bitrates for each clip, which can be good or not so good, depending on the material. That’s a whole discussion though for a different day…
    David Roth Weiss
    Director/Editor
    Los Angeles
