Activity Forums Adobe Premiere Pro Rendering .avi from another machine to PPro Error
  • Rendering .avi from another machine to PPro Error
    Posted by M on February 6, 2007 at 4:50 pm
    Hello,
    I am getting these errors on our Adobe PPro v.2.0
    Adobe Premiere Pro Memory Usage is Very High
    then immediately following this error:
    Microsoft C++ Runtime Library Run Time Error
    These errors occur after I have taken a a .dps file from DPS Velocity (about 10 seconds of video and audio)ad turned it into an .avi. Put it into a common folder on our network. Then, I copy that .avi file from Velocity onto the hard drive of the Adobe PPro. When I import the .avi into my project and then put on the timeline everything is fine. When I begin to render the file (after a few seconds) I get these two errors almost at the same time. Sometimes the machine locks up and I have to reboot. Sometimes it churns away forever and tries to finish rendering this 10 second segment.
    Does anyone know what this is a symptom of and how I can make it go away?
    Thanks for any help.
    -Matt (lokfreek)
    Blast1 replied 19 years, 7 months ago 3 Members · 3 Replies
  • Aanarav Sareen
    February 6, 2007 at 6:31 pm
    Matt,
    Does this error occur with any other type of file?
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • M
    February 6, 2007 at 7:44 pm
    I have imported wmv, mpg, and quicktime. Quicktime had some issues when trying to put two particular clips next to each other. Don’t know if we a file problem or a problem with Adobe not liking the quicktime.
    A few of the other avi’s (this specific time)have worked fine. Some do not.
    I re-encoded (is that the correct term?) all the avi’s from the Velocity just to make sure that it wasn’t just a corrupt file and still had the same problem with the same clips.
  • Blast1
    February 6, 2007 at 7:45 pm
    [lokfreek] “These errors occur after I have taken a a .dps file from DPS Velocity (about 10 seconds of video and audio)ad turned it into an .avi.”
    What kind of AVI file? a MSDV type 2 AVI would work best.
