Activity Forums VEGAS Pro rendering AVCHD to DVD
  • rendering AVCHD to DVD
    Posted by Peter Brown on October 24, 2011 at 3:03 am
    I have had several attemps to get a good quality DVD from my AVCHD file (1920 x 1080) i
    I have tried rendering settings of PAL DVD, PAL DVD widescreen and DVD Architecht video stream PAL,
    All of these setting worked fine except I get jitters where vertical or horizontal lines are present close together in the movie. ( like window frames etc)
    I tried rendering in another program (pinnacle) and it was fine no jitters?
    can anyone adise
    Peter
    John Rofrano replied 14 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    October 24, 2011 at 10:51 am
    Make sure that you render using BEST mode. BEST will use a resizing algorithm that will get better results than GOOD. Most render templates use the settings from your project so just change the template to use BEST (press Customize Template and look on the Project tab under Video render quality)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Peter Brown
    October 25, 2011 at 8:45 am
    Thanks John,
    I tried what you said rendering in “main concept MPEG2” and moving the “slider” all the way up to maximum quality,
    The results were no better,
    I then had a look at the results that were satisfactory from the “pinnacle studio 15 program” I was trying as you will remember these were better results than the Vegas results with no jittering on the parrallell lines etc.
    I noticed that the pinnacle program renders at 85,000bps and sony only 60000bps,
    So I tried the Vegas again but this time upped the bit rate to 950000 and the results were much better.
    Please advise
    pete
  • John Rofrano
    October 25, 2011 at 10:49 am
    [Peter Brown] “I tried what you said rendering in “main concept MPEG2” and moving the “slider” all the way up to maximum quality, The results were no better,”
    That’s not what I said to do.
    Go to the Project tab under Video render quality set it to Best.
    ~jr
