Rendering AVCHD onto a DVD
Posted by Anders Hjelmseth on November 20, 2009 at 7:07 pmI am a current (bought and registered) user of Vegas Movie Studio Platinum, an have lately been having some problems…
The footage is shot with a Sony HDR SR1E in AVCHD 1440x1080i.
I have rendered about 1 hours of video (17 tracks – longest up to 12 minutes) in *m2ts 5.1. I find no possibility to render to AVCHD in DVD Architect 4.5 (or 5.0 – trial).
The only way to play the AVCHD seems to be to reload to the HDR, or make a AVCHD disk through Sony PMB, which I can play on my Sony S550 DVD player.
Hove come, DVD architect not supporting AVCHD?
LessIsMore
Stanislav Dusek replied 16 years, 7 months ago 6 Members · 10 Replies -
Rob Franks
November 21, 2009 at 3:00 amDVDa 4.5 does not support avchd
DVDa 5 does support dvda but the trial does not come with full codec support. You get full codec support once you purchase the program.
Odd Magne nilsen
November 21, 2009 at 6:58 am -
Anders Hjelmseth
November 21, 2009 at 4:08 pmInteresting possibility!
Which I will look into.I was a bit confused and irritated yesterday evening. And by a good night sleep, I wanted to give it a last try.
I changed the DVD architect project to a Blue Ray project, with 1440×1080, split the project into disk 1 and disk 2. Rendered and burnt it on two 4.7 Gb DVD+R.
I burned them, and can play them on my computer which do not have BD, or on my TV, through a Sony BD S550.
End of story, it worked out OK, and I am able to enyoy full quality in my living room.
LessIsMore
Anders Hjelmseth
November 22, 2009 at 8:20 pmHello there!
I used a Optiarc DVD RW AD-5170A, and not a BD.
LessIsMore
Odd Magne nilsen
November 25, 2009 at 6:05 amWhat is your settings from importing the video to the timeline till burning out?
odd magne nilsen
newbie
Anders Hjelmseth
November 25, 2009 at 6:28 pmI set the Vegas project to HDV 1080-50i (1440×1080; 25.000 fps) and 5.1 surround. I rendered with Sony AVC into *.m2ts using AVCHD 1440×1080-50i, 5.1 Surroud.
I set the DVD Architect project properties, Disc Format to Blu-Ray Disc to and video format to AVC. Audio Format set to AC-5.1.
It burned nicely to AVCHD on my DVD disk.
LessIsMore
Stanislav Dusek
January 27, 2010 at 10:31 amYou did not created AVCHD on DVD. You created Blue Ray format on DVD. It is something else. Fortunately both formats are playable on most of the BD Players. But if you try Playstation 3, you will not be happy. PS 3 supports only AVCHD on DVD and it is not your disk. Recently I solved the same problem. DVD Arch 5.0 is not able to create any AVCHD format on any disk.
Bernard Ageeb
February 8, 2010 at 12:27 amHi Stanislav,
I just rendered my project in Vegas 9 pro to AVCHD 1440x 1080 601. So i can’t put it on disc with DVDA 5.0?Bernard
Stanislav Dusek
February 8, 2010 at 1:28 pmHi Bernard,
You can do it, but not for PS3 on DVD. I wanted to tell something else. The main thing is that we must distinguish two aspect. Datafile format and medium format. Datafile format can be AVC (AVCHD) you have created by Sony Vegas 9 or MPEG2 HDV format and many more. Medium format is the structure of folders, data file formats etc. The medium format may be AVCHD, Blue Ray. Theoretically both formats may be burned on any medium (BD-R, DVD-R, … etc). If you want to burn your HD film with authoring process (It means with menu) by DVD Architect v5.0 you can create only Blue Ray media format on any media (BD-R, DVD-R, DVD+R, DVD-RW, .. etc). If you use the DVD medium, you have DVD medium with Blue Ray media format only. Not an AVCHD media format. DVD Architect v5.0 is not able to create AVCHD media format. This Blue ray media format can have more data formats of film. The data formats AVC, VC-1 and MPEG-2 are acceptable formats for Blue Ray madia format. If you have a film in AVC format from Sony Vegas, you can create only Blue Ray medium format with AVC files on DVD media. It is NOT an AVCHD media format. And PS3 is not able to play this disk, because is expects AVCHD media format on DVD. If you want to burn your AVC film for PS3 by Sony DVD Architect v5.0, you need to use BD-R disk! But other Sony players (BDP 360 etc.) are able to play Blue Ray media format from any medium. It means HD film prepared on Blue ray medium format on DVD. If you want to make an authoring film with menu prepared by Sony Vegas 9 as AVC and burn it onto DVD medium playable on PS3 you should use another software like Nero 9 Reloaded.
Good luck in your video.
Stanislav
