Activity Forums Adobe After Effects rendering audio transitions…
  • rendering audio transitions…
    Posted by Andrew Donaldson on January 10, 2012 at 12:46 pm
    Hi guys, just a quickie…
    I know After effects is pretty lame with mixing audio, but when i do a simple audio cross dissolve between two tracks, it always renders out funny.
    I keyframe a cross dissolve between two audio tracks and the RAM preview sounds great. But when i render out the comp the audio dips to 0 before coming back up again.
    The best way i can describe this is that if it sounds like it dips to 0 (-48db) during the transition.
    The render settings for audio are pretty simple, Am i missing something?
    I know i could mix it elsewhere, but its a really simple little cross fade that should sound smooth-like the RAM preview does, am i doing something wrong?
    Thanks for your thoughts…
    Andrew.
    Cassius Marques replied 14 years, 7 months ago 2 Members · 1 Reply
  • Cassius Marques
    January 10, 2012 at 7:28 pm
    precompose the transition, so your output comp sees only one audio layer, it should come out the way your hearing inside AE.
