Activity › Forums › Adobe After Effects › rendering at quarter resolution
  • rendering at quarter resolution
    Posted by Johnny Smith on June 29, 2011 at 5:31 am
    I animated an effect heavy clip at quarter resolution ( i’m talking about the setting next to the “active camera”, below the image ) and unfortunately when I render normally it gives me a totally different and undesirable look. How do I render ( i’m using ProRes 422 ) @quarter to match the preview?
    Johnny Smith replied 15 years, 3 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    June 29, 2011 at 7:55 am
    My first question would be why do you need to do that? If it’s just for preview reasons to send to a client, I would recommend using Adobe Media Encoder- open the AE project in Encoder, choose the comp you need rendered and then render out using a preset.
    You can also choose to “stretch” (shrink) the image to a smaller size in the Render Queue.
    https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103a4f2dff7-79dba.html
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Johnny Smith
    June 30, 2011 at 12:14 am
    Certain settings in trapcode form look much better in a quarter view than full view. Especially in Motion Preview Render Mode. ( i like the downsampling look ). Not sure if shrinking the image would solve this. Also the link you posted does not explain how to shrink the image.
  • Walter Soyka
    June 30, 2011 at 1:44 am
    [Johnny Smith] “Certain settings in trapcode form look much better in a quarter view than full view. Especially in Motion Preview Render Mode. ( i like the downsampling look ).”
    You could precomp your Form layer, then pre-render [link] or proxy [link] it at quarter res. If you use proxies, make sure you set your final render’s render settings to Use Comp Proxies or Use All Proxies.
    If you really need hard, nearest-neighbor scaling, you can use Draft mode on your low-res pre-render. Just make sure to set your final render’s settings from Best to Current.
    Walter Soyka
  • Johnny Smith
    June 30, 2011 at 5:49 am
    your method (both pre-render and proxy) produced a quarter sized final image that looked different than my preview window. I’d like the final image to be full size ( 1920×1080 ) but with quarter resolution so it would look just like I see it in my preview window.
